I just got my fist boat a javelin with a 1993 johnson vro 2 stroke. I have a few questions because i'm pretty much clueless with boats. When i picked up the boat my buddy knows alittle bit so i had him come with me. We had the owner start the engine and there was a steady stream of water. Which was good and also spun the prop for a few minutes making sure it ran right which it did. The previouse owner told me When he tryed to start the boat with the motor with it trimmed up some gas leaked out the carb. Is this alright? Is there anything else i should look for befor i go and take it out on the first test run?
I read about this vro system alittle bit and do you guys sapose i keep it or just mix oil manually. Any info on what to check on or lube or anything basically befor i take it out is appreciated im a new to all this thanks.
