Tommywalton
- Apr 23, 2010
- 170
Ive found a few similar posts but not exactly what i need. I am about to buy an unusually well maintained chapparell 2300. 89 or 90 not sure. Its so clean its unbelievable. Less than 200 hrs. Anyway it has a bum engine. Rusted from its last outing. Water in through exhaust valves. So i know i need riser kit most likely. My delima is i have an 86 capri with a 5.7 its a 2 piece rear seal. The capri was a 1 piece 305(aq225) originally. I bought a corvett flywhell, 12" and made the 2 piece set up work. So i want to use the 2 piece 5.7 in the chapperall also. Problem is the coupler for the omc connects using flywheel bolts:/ . My 2 piece crank flange wont bolt to the omc 1 piece coupler. Does anyone know of a source for this 2 piece flange coupler? Ebasicpower.com has them on back order. Thanks
