Mourning everyone. I have a 1989 evinrude te25elceb it will run great for two miles and then just shut down won't die just idle has new HEAT sensor and thermastaty
Is it flowing water well? Sounds like a failing rectifier or powerpack. And by the way, I am not mourning, hope you arent either.![]()
my bad will bog down then in time it wil goHmmm sorry bro this sounds a little over my head. I have a hard time understanding howu you have have the throttle open and stmill idle well.
Oh okay, now were talkin!! First make sure the primer bulb is staying hard. If not you may have a fuel pump issue. Try and pump the bulb and see if the motor stays running.If not we need to start troubleshooting the ignition system. If it was in the
