which gear oil?
ktryan
Hi guys, im new to the forums and to boating for that matter. i just bought an old glastron with a 1977 70hp Evinrude model 70773S and i need to know what type of oil to put in the lower unit. thanks
tx1961whaler
Re: which gear oil?
Regular old 85-90W marine gear oil.
It is not an electric or hydraulic shift gearcase.
archcycle
Re: which gear oil?
yes only use marine grade gear oil. it contains water emulsifiers to help slow corrosion if water starts leaking in.
robert graham
Re: which gear oil?
While you're getting your Marine Lower Unit Oil at Walmart, buy the small Hand Pump used just for that purpose, to pump the oil into the Bottom Drain Hole.
scuba_redneck
Re: which gear oil?
I agree 1000% with robert!!! It makes things much easier to thread into the port and pump away compared to squeezing oil out of a tube and maybe getting it all out.
