ptt wire routing PLEASE help!
upnatm
2003 Johnson 90hp 4-stroke (J90PL4ST). Had to replace the engine mount. Once I cut the %#@! thing off, all went smooth until I tried to reinstall the lower cowling. Can't for the life of me figure out how the ptt wires route through the lower cowling on the port side and through the engine mount to the conections on the solenoid. Any takers???
daselbee
Re: ptt wire routing PLEASE help!
On the 70, the PTT wires go up thru a grommet in the center lower engine cover. Not the side covers, that center plastic piece that is directly above the steering arm. Should be a grommet there.
