I am replacing a 89 3.7L 180hp that is locked up with a 83 470 170hp. I have swapped the manifolds over so that everything links up and it will bump up to the 180hp as the othe engine is. My question has to do with the fuel pumps. On the 89 engine, the fuel pump has the bowl at the bottom of the pump. On the 83, it has the bowl at the top. I checked and both engines have the same cam shaft. I just needed to know if I am going to hose up the engine if I put in the other fuel pump. The levers are in different positions on them. Any help would be appreciated.
