Re: Anodizing or Protecting Raw Aluminum
It's some high tech stuff. Used for car chassis in the beginning but they've been branching out into other colors and products. They have bottles of a spray on then rinse degreaser and then a second product that etches to give the product something to bite to. I used the Whitecote product to do my trailer. You can hit my friend's car chassis with a hammer and that stuff will not chip or crack.
Not sure exactly what the Glisten stuff is like but it sounds like it used the same moisture curing as the chassis paint.
http://www.por15.com/Data%20Sheets/glisten%20pc%20directions.pdf
A Brilliant Two-Component Clear Coating
GLISTEN PC is a High Gloss, Rock Hard, Water-clear topcoat designed for spray or brush application over all metal surfaces, including highly polished aluminum and chrome surfaces. GLISTEN PC will not leave brushmarks, and will dry in less than one hour, but will take 3-4 days to reach maximum hardness.
When GLISTEN PC is first dry to the touch, it will appear to be very soft. Avoid touching it for several days until it becomes hard and tough. Accidental contact could damage the surface before full cure has taken place. Like many other coatings, GLISTEN PC is a MOISTURE-CURED coating, which means it is strengthened by exposure to moisture. It will never crack, chip, peel, or yellow, and is very flexible as well.
Note: When applying over polished metals (aluminum, chrome, brass, copper etc) you must use AP120 metal prep according to instructions.
IDEAL USES: As a protective coating on aluminum wheels, chrome bumpers, marine railings, chrome or aluminum covers, grills, handles, ornaments, lights, etc
Introduction to POR-15?
POR-15? is a high performance, versatile aromatic moisture cured polyurethane coating designed for application directly on rusted or seasoned metal surfaces and concrete. It dries to a rock-hard, non-porous finish that does not chip, crack, or peel. Because POR-15? is non-porous, it is an excellent sealer for porous substrates and it completely protects from water, chemicals, salt, and mineral oils. The highly porous characteristics of most substrates and traditional coatings permit harmful elements to penetrate which initiates deterioration. POR-15? is the only coating that is able to protect and extend a surface or structures life expectancy due to its unique non-porous molecular composition. POR-15? is also able to withstand prolonged exposure to temperatures up to 500 degrees Fahrenheit.
Is the por15 like paint? Epoxy? Does it get really hard? I've never used any of their products...
