dhildebrand
- Jan 12, 2012
- 43
I have a 2010 Q7 SF. I mounted the hummingbird transducer by installing a tee fitting on the drain tube from the small compartment on the starboard side and routed the wire through it. No additional hole in the transom. Anyway as it turns out the best place to mount the transducer was beside a small wire that was already installed and routed down and stops at a small (brass?) fitting. Is this the transducer for the factory installed Depth finder? I believe it to be the temperature sensor for the factory unit. Anyway, when the Hummingbird unit is on, the factory unit will work for about one minute and then lock up showing a depth of .4 feet. If I turn off the hummingbird and reset the Factory installed unit, it will work. Turn on the Hummingbird and it stops within one minute. Anybody out there have any ideas to the cause and a possible fix? Hummingbird seems to work either way.
