It has electric start, with auto choke. There is a small nipple on the bottom front portion of the engine, its under the air intake and it drips (very ,very slowly) what looks to be oil? Is it supposed to be connected to another part of the engine for lubrication? I have searched this entire engine and can find not one single open nipple that it would connect to. I do NOT have an air cleaner on this engine ans was wondering if that is where it is supposed to get hooked up?? Do i need an air cleaner? most peoplke have said no dont bother.
To give you an idea of how much oil has come out, i have had it in the water about 5 times, run thru 2- 5 gallon tanks or fuel and there is less than an ounce of oil in the bottom under the engine.
Where can i get the engine schematics and will that show where it is suppossed to get hooked up?
2nd part of question:
The engine runs great with the exception of it stalling out when putting it on the trailer and giving it light throttle, when i do ... it stalls. In order to get it up on the trailer i need to really throttle up to get it to go, do i need a mechanic to make that adjustment or is it a fuel mixture issue as i do like to run it a little on the rich side.
Plugs are new, wires are new and just had it tuned up and checked prior to putting it in the water. I bought it just a few wks ago.
