question about bellows
popsmazz1
I took my boat to have the impeller replaced alfa 1, when I got home I found the exhaust bellows had come off up by the transom. I managed to get it back on but I"m not sure it"s on properly. it"s on far enought to tighten the clamp trough the hole in the side. Is that all there is to it or should do something else?
tpenfield
Re: question about bellows
Some adhesive sealant in addition to tightening the clamp.
rickryder
If you check your service manual it tells you what adhisive to use.
