1992 25 hp Mercury not pumping
Matt t
I just bought a 25 hp ,d134012. It needs a water pump. I was running it and there was exhaust coming out the tell tale, pee-hole. Any idea if this is normal or if there is another issue also. Thanks. Matt
Matt t
Re: 1992 25 hp Mercury not pumping
That engine has a thermostat set to 120 degrees.
The engine is a model:
1025201MD MERCURY 1992 25
Parts Listing:
http://www.crowleymarine.com/mercury-outboard/367.cfm
Service Manual P/N: 90-43509-3
Here is a good deal, grab it while you can:
http://www.ebay.com/itm/Mercury-Mariner-Service-Manual-18-20-7-25-HP-Motors-/120852374556
Gerry
Thanks Gerry.
I replaced the pump and found that the rubber water tube had a hole in it. It pumps great now. I am having an issue with the idle. Not very smooth. I tried to adjust the carb but it still is rough. Choked it a little and the idle seemed to increase. I had cleaned the carb but it still seems to have an issue. I don't know how long it really has been sitting.
