Re: Wot
Hi barleyfloatin. Welcome to iboats. What type of motor do you have? Regardless of the make and model you should NEVER, EVER run your motor at WOT on muffs, or in a test tank. It should only be done on the open water, under normal load. Most motors actually have a mechanisms to prevent over revving in neutral, in fact. Also, be sure that your motor is even designed to run on muffs in the first place. Most vintage motors need to be run in a test tank with water filled to an inch or so below the main exhaust port and should never be run on muffs like modern motors.
