I have a 1999 Javelin Renegade 19 with the 175 Johnson on it.This is my first bass boat and i enjoy the boat but it is giving me issues.When i first unload it at the lake and take off it works perfect or to the best of my knowledge it does.Starts up first or second turn every time and leaves good.I can trim around on the engine when going Wot and it reads about 42-4300rpm and to my knowledge that is performing its best .But after fishing a day and going to start back to the dock it loses all power ,starts missing,Rough idling where you can fill it shake the boat and takes forever to plane out ,But usually when it gets on plane it is fine .Well today it never made it on plane and i managed to get it to run maybe 5-10mph at WOT.This is the worst it has even done ,at least before it would finally get on plane and run faster
The boat ran fine all day up until that point.Stayed about the same 4200rpm at wot,never missed or made any noises.Shut it down, fished started it back up to leave and it started doing this again.Never fails to do this,And it always happens after you are running somewhere and shut it down fish then start it up to leave is when it goes crazy.
I have no way of telling mph as the speedo does not work but the Rpm tack does.So i have no way of knowing even if when it seems to performing Good if that is up to par.But i looked at the prop and it has a raker 14 1/2 x 24 3 blade stainless .
I have checked the fuel filter,made sure carbs opening up wot,new plugs gaped at 30 and using stabil in my gas.It is very Random when it does it and usually only happens after a day of fishing where you are shutting the boat down and starting it back up .And on times when i assume it is running the best it is turning 4200rpm .I just am lost guys and have no idead what it is or what to check
