Right bit fed up with my boat that i have not really managed to use yet. When i first bought the boat the ring gear was gone on the flywheel. so now replaced that and the starter. Anyway got it all back in the boat etc, and fired up no problem,had the engine stopped and started a few times, then took it to the sea to launch it, and tried starting it, felt like a flat battery, didn't have power to turn it over, so i thought after lots of different battery's etc relised this was not the case, so took the engine back out, starter off to find the housing all cracked(new starter). I then took the plugs out etc and turned it over by hand, but the engine still felt quite tight, but sort of free'd off, took the sump off and no obvious signs of anything. How easy should you be able to turn these over with no plugs in it?
Any ideas??
ITs a volvo penta 570 model 5.7 v8 in a pro craft( mastercraft sort of ski boat)
failing this, anyone in the uk know of an engine for sale or a block??
Any ideas??
