DTS conversion
scoflaw
Ensign
Anyone done this? How difficult and how expensive for the boat in my sig. Shifters are brutally stiff.
Re: DTS conversion
Ayuh,.... What the 'ell is DTS,..??
Ya probably need new shift cables...
dubs283
Re: DTS conversion
digital throttle and shift - all shifting and throttle is controlled by wire and servos mounted on the engine
used in conjuction with smartcraft so the op would need smarftcraft as well, and i believe the ecm needs dts software as well
the real question is why are the shifters so stiff?? have you done any troubleshooting??
scoflaw
Ensign
Re: DTS conversion
Boat is like new. Common complaint with others as well. If you loosen up the shifter tension, the motors won't hold RPM. Yes I have smartcraft.
Don S
Re: DTS conversion
If you have smartcrart, you should be able to use the DTS. I't not going to cheap, I can tell you that.
Do you have a 10 or 14 pin harness connector?
scoflaw
Ensign
Re: DTS conversion
DTS was an option for my year. Will have a look at the connector. I would do this install myself. How involved would it be if I did in fact have the bigger connector?
Don S
Re: DTS conversion
Below is a file on the 10 pin setup. The first part is an overview of a Mercruiser setup showing the parts on the engine you would need along with the basic parts up to the control
The last page of the file is just a wiring diagram from where the control plugs into the engine. Could be outboard or IO, or inboard, that part is the same. The engine parts are what is different.
View attachment DTS.pdf
