1981 johnson seahorse 4hp wont run but at half choke
xjam721
i have a 1981 johnson seahorse 4hp that will run at full throttle to half throttle but less than that it will only run with half choke
tx1961whaler
Re: 1981 johnson seahorse 4hp wont run but at half choke
The problem is likely the low speed circuit in the carburetor. The carb will need to be removed and thoroughly cleaned.
BUT, before you tear into the carb, check that it is sparking on both cylinders and that the cylinder compression is even across the two cylinders.
