water pump I6
Sangster21
Hello, I have a 1976 Mercruiser 165. I have the engine out of the boat and would like to replace the inblock circulation pump while it is easily accessible. Can I go to an auto parts store for this part, or does it need to be marine specific? The engine does use a heat exchanger, so the pump will only see anti freeze.
Thanks,
Alan
achris
More fish than mountain goat
Re: water pump I6
If you are using coolant and not seawater, then a standard automotive pump will be fine, and seriously less expensive than the Merc genuine article...
Chris.......
Re: water pump I6
you should be able to pick one up from any of the local autoparts stores. the engine is a GM 250 cubic inch six. if the local autoparts store clerk cant look up marine engines, have him look up a '76 1/2 ton truck with the 250
Re: water pump I6
Thanks,
Alan
Ayuh,... If it ain't Leakin',... There's Nothin' wrong with it...
In yer application, they'll last darn near Forever...
Fishermark
Re: water pump I6
Not only that, it is still incredibly accessible even with the engine in the boat, unless your boat is arranged in an unusual way.
Sangster21
Re: water pump I6
With the belt off, spinning the water pump results in a somewhat unhappy bearing sound.... while the engine is sitting on a stand, I think I will go ahead and replace it. I will ask the local auto parts guy for a w/pump for a '76 half ton I 6. Thanks.
Alan
