fabenarroyo
- Apr 2, 2011
- 4
Ok Guys, here is the story, I parked the boat in November last year in my garage with 1 or 2 gallons of gas. A month ago I decided to replace the impeller, I did and I tested the motor on my driveway, not the lake, everything looked fine. I also replace carpet, recharged the battery and make sure that everything was in good shape. Yesterday, I put 10 gallons of gas and I took the boat to the lake, and then, the problems started. It was idling fine and when I put the boat on plane it only did it for 3 minutes, after that it seemed like the engine lost power and ended it up stopping. Finally after a few minutes, it started and I headed back to the ramp. On my way back, I decided to try it again and it was running at 4400rpm for probably 25 minutes, after that.....again, lost power and ended it up dead, I did the same again and this time I headed straight to the ramp determined to get the boat out the water, I kept the engine running at 2300rpm (of course not on plane) I tried 2 times to get it on plane, but as soon the motor got to 4400 rpm (I normally set that rpm for cruising) it started to lose power and stopped. I noticed then, that the engine wasn't running on it's 3 cylinder. My girlfriend was searching online meanwhile and discovered that the old gas could be the cause of the problem. So, please tell me what to do now, and what do you guys think about this issue.... Thank you much!!!!
