5.0 GXI-G - 2007
38693464
242 Hours
DPS-A 1.95
3883609
Carter Fuel Pump Assembly
P61341S
I have scoured the posts to see if this issue has presented itself before and my symptoms are slightly different than anything I have found. If this is a duplicate question please reply with the link and I will be on my merry way and apologize for duplicating a previously asked/answered question.
Engine starts and runs great under load, no squealing present, no squealing upon starting and idle for the first 5-10 minutes either. However once the engine gets to normal operating temps it squeals, I engage the throttle, no hesitation, no surging, and no squeal over 2200-2500 RPM's. The squeal returns after the boat is returned to idle speed, albeit not immediately (usually within 2 minutes of idle) under 2000 RPM's. These are the symptoms I cannot find a similar comparison too. Seems to be the opposite of other fuel pump issues? The boat will idle without surging or stalling but the noise is atrocious. It has done this for the last 4-5 times out on the water and progressively getting worse.
I have checked all connections for tightness, applied plumbers putty to the brass connection made sure the proper clamp type and sizes are in place and secure. It sounds to be coming from the High Pressure pump but not 100% certain. JustJasons/Don S. pressure rig is next on my list and plan to perform the pressure checks as outlined, but thought to ask if this just might be clogged screens at the pump inlets since performance doen't appear to be negatively impacted and increase fuel volume abates the noise. WOT is good with no hesitation and still achieving top speeds/acceleration as before noise began. Plus splicing the fuel lines is still unclear to me and my limited diagnostic experience.
Boat never sits more than a few weeks and I run E free fuel through it ALWAYS. Is there a tech manual that will outline how to check and clean debris in the Carter fuel pump assembly? Is it a good idea to remove the assembly and spray it out with carb cleaner? The thought of $700 for a new fuel assembly doesn't register high on my personal excitement list, nor guessing on the replacement high pressure pump component, but with an upcoming trip to the Keys I'd rather err on the side of caution.
Any insight, time and consideration is greatly appreciated. Thanks guys.
I do have a short video I can share if this will help.
38693464
242 Hours
DPS-A 1.95
3883609
P61341S
