I have a 24' Sweet water pontoon boat with2- 23" DIA pontoons ( dry weight 1920lbs) with a f70a yamaha 4 stroke ( wot range 5300 to 6300 rpm ). Test weight with motor , gas , gear and 2 people is apx 2750 lbs. Prop #1 is 13 5/8 x 13 . WOT is 5400 to5600 rpm speed 23mph gps . Will not reach 6300 rpm . Prop #2 14x11 . WOT exceeds 6300 rpm , speed at 6200 rpm 19 mph gps . The boat and motor are new , set up looks good . What prop to try next . I noticed on most of the yamaha performance pontoon boat test they used the 13 5/8x13 prop and only listed 5400 to 5700 rpm's . All the info I read says you need to reach close to max WOT rpm,s . Thanks for any suggestions .
