Hi all!
I've been working on my Johnson QD-18 10 hp, hoping to get it running and tuned. I did the points, coils were ok (previously updated), good spark, did water pump, dumped lower unit and refilled (slightly milky, found no gaskets on drain/fill plugs-maybe...), did carb kit w/ float, putting it all back together, and found a problem.
When I took the carb off and began to disassemble I noted the way the packing nuts/tubes were put on and what springs and washers went where. It was like this:
Bottom (high speed needle): had long packing nut, large spring, large rubber donut/grommet, brass washer, plastic grommet
Top (low speed needle): had short packing nut, smaller spring, plastic collar
While looking at the parts diagrams in my Seloc I saw that the longer packing nut goes on the top needle. I began swapping parts and cannot find a way to get them all together so the faceplate fits inside the shroud correctly. I even checked Fleabay to see if there might be a carb like mine for reference. I can get the parts all together but it seems I either end up with not enough needle stub sticking out to to get the knobs on, or the faceplate goes on way crooked and cannot get the shround to sit down with faceplate in position. I've tried every combo I could think of.
I'm wondering now if Freddy Fingers before me has non-spec parts in there or what.
Can you guys take a look and see what I'm not seeing? Maybe look at another QD-18 for ref?
Pix below show carb w/ needles and packing nuts installed, parts laid out and numbered, and diagram from manual.
(Rubber donut in middle does not show on parts diagram, was installed on long packing nut on lower needle w/ large spring and washer/plastic grommet. I can see where the spring has been chewing away at it.)
Thanks in advance!!!
