I have a 1993 Evinrude 40HP. My propshaft seal started leaking about 6 weeks ago. I've removed the prop, etc and I'm getting ready to pull the bearing carrier. Is there any other recommended service to do while I have that out?
The history of this motor is unknown to me. I've had it about 10 months and when I pulled the prop, it looked like it had been 10 years since it had been removed last with all the corrosion.
I'm going to work on it while attached to the motor on the boat. I know you're supposed to drop the lower unit to disassemble, but after looking at the steps, it looks like it will be fine to replace the seals while attached to the motor.
Is there any point to try and pull and inspect the reverse gear, since it looks pretty accessible as well?
Are the needle bearings difficult to change and should I spend the $40 on parts and get those as well?
Does anyone know what all is included in the Evinrude gear case seal kit 0433550?
I plan to drop the lower unit at a later date to replace the impeller and possibly the drive shaft seals.
