electric b
- Mar 14, 2012
- 5
I have a 1983 checkmate 20 footer that had a gm 350 mercruiser carberated. The motor froze so I purchased a 2003 350 mag EFI from a marine engine rebuild shop. After installing the new engine and making some water pick up mods for cooling we have her running. After about 15-30 min on the water she starts to spit and sputter then dies. I have figured it out to be fuel as the TBI stops injecting fuel at the time. It will not even start back up when this happens. If I go back to it the next day she fires right up but leaves me stranded again avery time after a short ride. I also noticed that the new engine does not have as much power as the old carbed one and also does not souynd as snotty from the thru huill exaust. Maybe the sound is muffeld from the added water running through the cooling system? Maybe it is not as powerfull because I have an issue with fuel? I thought that this newer EFI had 300 hp at the prop unlike the old that was a 260 at the flywheel. I have attempted new water seperator 2 new fuel pumps. I have taken the fuel pick up line out of the gas tank to check the screen. I have read a thread about another guy who sent his computer to get reprogramed. Did the rebuild shop put the wron computer on this engine. I am questionable about fixing this if it is not going to be more powerfull than the old carbed engine. I am thinking about going back to an old carbed engine. Please help anybody?
