Gennadiy05
- Jul 28, 2011
- 5
Hello, i have a omc conra 4.3 liter v6 engine with an omc outdrive
I bought this as a project boat and completly rebuild it and also had taken the outdrive apart last summer and fully resealed and also ran it last winter once before winterizing it. Everything was perfect.
Today after deeinterizing it and starting it for the first
Time, i ran it for a few mins with the ears and my garden hose attached to check everything. Everything was working fine. After opening the oil dipstick to see the amount of oil,
I found the green oil to be milky and foamy.
So i understand a little water got into the system.. Is that safe to ride this summer with? I will check oil before every use and add if neccesary or do i need to reseal it again?
Thank you
Thank you
