rednecktech00
- Aug 28, 2005
- 75
I have a Mercruiser 3.0 with and Alpha 1 Gen II. It is on a 1988 Mark Twain 175 which I dearly love. The engine was replaced with a brand new one from Michigan Motorz in 2009.
Would like to pull my drive to check all the stuff that needs to be checked every year. Will also change the impeller. I will build a cart like one shown in the sticky.
Question is this. When I put the drive on, will I need the alignment tool? I am not understanding why the alignment would need to be reset if the engine is not moved.
Is checking the alignment just a good idea in case the engine has shifted during normal use?
