have a 78 pre alpha drive on a 250 cu in, 165 hp merc. just recently replaced the ujoints as they were vibrating and noisy. reinstalled drive and did a water muff test. while the unit is in neutral and running, the drive is quite and doesn't jump, but kick it into either forward or reverse, it has a sporatic 'thump' and when it does this, the drive jumps sideways a little. adjusted the lower shift cable at the mount, but it still has the thump while running in gear. the prop locks into gear strong and the ratchet drag feels the same in both directions. tried listening to drive with a wood pole but inconclusive as to where the noise is coming from. by ear, it seems to be the lower area. drive wasn't doing this before the u joint replacement. did i screw something up? suggestions welcomed.
