Hi all, I've been lurking and learning for a bit now and finally started my resto mod. The old ratty carpet was replaced last year along with the casting deck, rework the open rod locker and repowered fom a 40 HP Force to a new Merc 90HP 4 stroke. This year I started with a fuel tank replacement/relocation and I'm ending up with a MAJOR upgrade resto.
New 76L under deck fuel tank replacing the old 45L above deck, Baystar hydraulic steering , merc monitor gauges, nmea 2k network, hds-10 with Structure scan 3d sonar, moving trolling motor battery fwd , reboarding ladder, new hatch install and hatch cover upgrades on the casting deck, new consoles, red/ white LED lighting for all compartments and deck lights, LED Nav lights, Horn, Audio system, full electrical replacement with custom breaker and switch panels, 400w inverter, solar trickle charger, built in bait well , washdown pump and backup bilge pump. The tear out is complete and I've started the rebuild, so far the consoles are built and wating to go in, the fuel tank is installed and the deck is going back in. I'll post a few with with comments and details to follow,
Questions and comments are welcome, Art
