Re: F4MLHY yamaha outboard year 2000
I'm pretty sure the cam is geared directly to the crank. (no timing chain). Find the flywheel alignment marks, check and see if you have TDC and reset the valve lash. Maybe you can make an adjustment once you get it running.
