1989 70 hp Merc
Bigaceks1
Idle's up good when not in gear,,but when trying to plane up,it is very doggy,changed out fuel filter and plugs,could it be the stador? Top speed 10 mph?
jerryjerry05
Re: 1989 70 hp Merc
Do a compression/spark test.
Then change/check all hoses and connectors.
Clean the carbs,rebuild the fuel pump.
Ethanol is not a friend to older hoses and inline connectors.
Check for water in the gas.J
BatDaddy1887
Re: 1989 70 hp Merc
...I had similar problem and the correct prop helped me. Did you change props?
CharlieB
Re: 1989 70 hp Merc
2 stroke idle circuits have to be overly rich, moreso then 'best idle' to provide the additional fuel necessary for the motor to accelerate.
As carbs dirty, the small idle passages show the first symptoms, poor acceleration, as the condition worsens then idle is affected.
Clean carbs, pay very careful attention to idle screw positions, G E N T L Y screw each one in until l i g h t l y seated and RECORD the exact number of turns so that once finished you can reset each idle screw to the SAME position it was before you started. This will save you LOTS of time adjusting idle afterwards.
sutor623
Re: 1989 70 hp Merc
Does this motor have the integral fuel pump in the carb?
oldman570
Re: 1989 70 hp Merc
You may try checking time sync the carbs along with cleaning with a can of Merc motor tune spray first off. Gas left in the carbs will evaporate and varnish the jets in a short time. Motor tune can be bought at marine dealers for around 10 bucks.
Oldman570
BatDaddy1887
Re: 1989 70 hp Merc
Once you get this fixed you may want to check into using Seafoam in the gas tank every now and again to keep it clean as it runs.
