Will OMC tach part no 291274 work for 1983 70 hp merc
butcher
My quicksilver tach no79 90767 burnt out and I have a new in box omc tach no 291274 can I make it work on my 1983 70 hp merc sn 7199360 .which the quicksilver tach was for.
Barnacle_Bill
Re: Will OMC tach part no 291274 work for 1983 70 hp merc
If it can be set for 6 pulses (6P) it will work.
butcher
This tach has no [ set ] method .Other than the light connections there are just two spades for push on connectors but no indication as to which each is for.I am guessing one is 12v and other is pulse , it appears it would be a case ground.would like to know what this tach can be used for if not for my 70 hp 1983 Merc.This OMC tach no 291274 says VDO at bottom of face does anyone know what engines it was used for.
