53 fleetwin 7.5 hp parts
TRAVAS_OH
First i want say thanks for the help on proper fuel/oil ratio last week. Now i need to find some seals and a
propeller shaft bushing. iboats does not seem to have any thing i need. So if anybody has good parts supplier for
this 53 7.5 hp evinrude fleetwin let me know . Even if i have to measure bushing inside dia. and outside dia, ect
to get one made i can . I have already found some o-rings for the upper housing and clutch rod seal . But i still need
propeller shaft seal and drive shaft seal . And ofcorse the propeller shaft bushing.
F_R
Re: 53 fleetwin 7.5 hp parts
Aren't those the funky seals with the ring around the outside? That makes them special. Not to worry though---
202686 Prop Shaft seal, $18.00
202274 Drive shaft seal, $11.65
276840 cap and bushing assembly, $11.41
All are available at www.marineengine.com
TRAVAS_OH
You were right on with that link . Thanks so much for the help . checked it out found every thing i need to get this
lower end sealed up . This is a realy good forum to be apart of, i saved the link so i could pass it on and help the
next person.
1946Zephyr
Yep. F_R is a very helpful person. You're lucky that he answered. :D
