seattle scott
- Nov 1, 2011
- 113
Here is Frank's set up. http://forums.iboats.com/showthread.php?t=533803&highlight=splined+washer ( See the first pic in the last post) I have the 3 parts that go on after the prop, the big washer, the little washer and the nut. I do not have any of the parts that Frank shows going on before the prop, including the first part that goes on ( the big thing, is that a zinc?) anyway I don't have a zinc and I don't have a thrust washer, or a splined washer ( with or without tabs that fold onto the prop nut. So what do I need?
I will post some pics if necessary.
Edit: I think I have the prop spacer or thrust washer F523099 that goes on before the prop, but I defninatly don't have the splined washer F523282, which I assume must be installed.
