Re: 1973 65 hp Evinrude Triumph Trouble!!
Is the choke knob set on the "Automatic" position? Do you have the warm-up lever raised? Are you holding the choke switch lever up while cranking it? Is the starter cranking it over pretty briskly? It won't start if cranking too slow.
Check the spark at 7/16" gap with the plugs in. If no spark, try it with the plugs out. If it now has spark, it is cranking too slowly. OR the ignition charge coils are shot (pretty common for the '73 motors). Look in the area under the flywheel for soft, leaky, or melted coils (the 3 big ones).
