GeorgiaMan
- Jan 19, 2012
- 11
I have a 89 johnson outbourd 2 stroke, it is a 9.9 .I am having fuel problems it will not stay running. What I have done is I baught a fuel pump repair kit, rebuilt it, looked over everything and it went well, when i put it back on figured it was the problem but, when it cranked, it ran for a few minutes then cuts off, dies....well you can prime it back up, and pull the choke and it cransk and runs till the gas runs out the carb. then cuts OFF. over and over, I have looked for leaky lines, loose lines,cranked line, everything looks good far as that. I went inside the carb to see if it was a sticky needle , and it was ok the carb looks clean. everythinggood on that.someone told me to try and pull the gas line out the carb and crank it to see if gas would come out the line and it don't . so i am guessing it is something to do with the fuel pump again. could someone tell me what they think could it be...
