Engine Coupler
Leedanger
Hey boys....
Can a seized up engine coupler restrict an engine from rotating? Working on a Merc 260 with an alpha one #5424302 and I can't turn the engine by hand at all. I got the cylinders soaking, but I was wondering meanwhile if the coupler could be the culprit.
stonyloam
Re: Engine Coupler
The coupler is simply a means of connecting the engine flywheel to the outdrive input shaft. As such it can not "seize". However the outdrive itself can, and prevent the engine from turning over. You need to pull the outdrive to check it. The outdrive always turns when the engine turns, whether in gear or not, the only way to disengage it is to remove it.
TilliamWe
Banned
Re: Engine Coupler
Yep, exactly what stony says. remove the drive, try turning the engine over. It it turns, your drive is seized. If the motor still won't turn, it's seized good!
Re: Engine Coupler
Ayuh,.... as stated above,... If ya don't have the drive off yet,...
Yer 6 or 8 nuts away from knowing whether ya got a junk motor, or junk drive.....
UncleWillie
Re: Engine Coupler
If it absolutely, positively will not move even a hair, it is more likely the engine. :(
If it will move even the slightest bit then it could be either. :confused:
The coupler,u-joints, and the rest all have a little play in them and would likely give a little wiggle room.
Leedanger
Re: Engine Coupler
wah...wah...wah....Motor toast. Thanks for playin'
HT32BSX115
Re: Engine Coupler
Now is the time of year for all the new threads on frozen engines and cracked blocks!
Poor (or NO) "winterization" will result in cracked blocks, and leaking risers and riser gaskets will result in water sitting in cylinders (with open exhaust valves)
It''s just simple high school "Physics".
Cheers, Y'all!
Rick
