Re: Experience towing heavy
8000 lbs. dry
1200 lbs. trailer (that's on the low side)
1000 lbs. fuel, water, gear, ect.
10,200 lbs. and your over the 9400 lbs. for the stock 3/4 suburban.
Even if you could get the boat weight down and drop all the gear, you will still be over the 9400 lbs. total, imho.
You will have to modify the Suburban and you will give up the ride and gas mileage when your not towing.
A 3/4 GM truck will handle that load, so the parts to upgrade your Suburban are available for a price.
Two differentials and all four springs along with proper shocks may be all you need, but 4:10 gears are far from cheap.
GM also recommends a class V hitch for over 10,000, so you would have to upgrade that also.
From chevy website:
2012 Suburban 3/4-ton
4x4
3.73 9,400
2012 2500HD Series Crew Cab
Standard Box 4x4
3.73 9,400
4.10 13,000 (class V hitch at 10,001 lbs.)
As for the Sundancer, great boat, have family/friends that had the 280 and liked the boat, used the marina, but all three upgraded to a bigger boat within 5 years. mmmm??? :facepalm:
Just have to agree with the others. GET A SLIP.
The price of the trailer alone will be close to the price of a dock. Your'll be suck at one location, but trust us, you will use the boat a lot more.
huts
