mcdonkey37
- Jun 12, 2009
- 19
Finally got the 73 evinrude 135 hp engine overhauled.
I have to break it in, but I can only run it for 5 minutes before its temp gets way too hot. The water is not cycling through.
I made sure the key was good, impeller is new, made sure the plastic sleeves to the tubes were connected in lower unit.
I did tap into the #1 cylinder to create a tell-tale, learning how to do that on iboats. (there is no stream)
The only way i get water is if I put on the muffs and apply pressure with my hands holding them there, then water cycles through and the engine is cooling.
What should I be looking for to do or fix?
thanks for any input or help,
Matt
Matt
