Re: adding blue sea add a battery question?
is the starting circuit and led optional?
The starting circuit disables the ACR to keep you from smoking it when cranking the engine.
NOT Optional. It is only one small hookup wire!
The LED lets you know if the ACR is working. Not absolutely required.
But why would you not want to install the system properly.
Your line of questioning indicates that you would attempt to install the ACR by doing
AS Little as Necessary.
It's purpose is to prevent you from being stranded at sea.
This is a potential life saving device.
If not installed properly, it become a live threatening device.
It should be install by doing
As Much as Possible.
If you have not read the directions In the link above, and you do not have the mind set to install it properly and completely, I suggest that you pass on this option.
It would be better to not have it at all, then have it installed half arsed.
Sorry to sound so harsh, I think they call it Tough Love!
