85-115 etlk where is trim tilt filler
gutts
Hello
Thanks for the help. Like the title says.. Where or how do i check the fluid level in the power trim tilt ? It goes up but sometimes it will not come back down. Do i need to bleed the air out of it ?
99yam40
Re: 85-115 etlk where is trim tilt filler
Low fluid or air will not cause motor to not come down.
Check relays, connections, and switches
gutts
The pump and all, is working properly. When it goes up all the way it seams to get stuck up there. Someone said maybe it was the pins were corroded and it was binding up? Also i do think there is air in there. A freind followed me down the road and said the motor was bouncing up and down a lot. It had not been like this before.
Is there a bleeder or filler somewhere on this thing? I cannot seam to find it if there is . I do not have a manual fot the motor.
Best
99yam40
plug should be on the reservoir ,
can you hear it pumping fluid and air?
Need to open manual release and lift by hand, lock in place in the up position, and then open to see level.
Look at a parts break down of your motor
gutts
Yes i can hear it pumping (humming). Thank you i will try what you said.
Best
gutts
yes OK i lifted it by hand, all the way turned screw back in let go of motor and it went down about 4 inches. I cannot see where to check the leval. Anybody have a picture?
Best
