duped
- Aug 26, 2009
- 307
Has anyone pulled a gimbal bearing using a threaded rod type puller ( like 45AUTO's ), WITH the bellhousing still on? In all the pics, they put the plate across the gimbal ring. I have a piece of 4"X12" 3/8 steel plate that I'd like to place between the drive studs ( running across the whole drive mounting surface top to bottom ) after I remove the shift cable.
Main question is, can the hinge pins take the force? I would assume so, but who knows how stuck the bearing might be. It's not rusty or crappy looking, but that can be deceiving.
It's not that I am trying to take short cuts, but I have a trim sender screw that wont budge, and rather than snap the thing off to get the bell housing off, this would be a doable work around.
