Last summer I had an issue with my engine not turning off and the Key switch shocking the crap out of you while attempting to turn off the engine. We fixed or put a band-aid on the problem by running a additional ground wire from the switch to the battery. Note this fix worked all summer.
Now today I rebuilt a leaking carb and while that problem is fixed my boat will not start. I have changed nothing with any of the wiring but I no longer have spark to any of the cylinders.
So I figure I may need to back up and fix my original key switch problem. Does anyone have any thoughts as to where to start trouble shooting this? I have tried a different key switch so that is ruled out. Any help would be appreciated.
