My spring has gotten off to a bumpy start. Let me tell you the tale...
I have a 1999 Glastron GS225 with a Mercruiser 5.7L Thunderbolt V Alpha One Gen 2 stern drive. I started having issues that seemed carburetor related last year, so I replaced the carburetor. It had a 2bbl MerCarb on it (one idle mix adjustment screw) and I replaced it with a Rochester 2GC 2bbl. It ran OK, but rich (black smoke) and I could never get it quite right. So this spring I decided to rebuild the MerCarb (which I kept in my garage). It is a fairly simple carburetor, so I thought I could handle the job. I bought the rebuild kit, disassembled the MerCarb and soaked it in parts bath, then hosed it off with carburetor cleaner and let it dry. I reassembled it with the new power valve, needle/seat, accelerator pump, check ball, etc., set the float levels according to a Mercruiser Service Bulletin, which said to set the float level to 10 mm and the drop to 27 mm. I set the idle mix screw to 1 1/4 turns out, and adjusted the electric choke as specified in the bulletin.
The engine runs, but it ain't right. I can't get a smooth idle. It wants to die when the choke opens, even when the engine is nice and warm. It surges. It won't throttle up smoothly- it goes from a 6 or 7 hundred RPM idle to a roaring 2000 RPM instantly, no matter how gently the throttle is opened. I have to believe I missed something in the rebuild, but I can't figure out what. I replaced the spark plugs since the other carb was running rich, and while I had the plugs out I ran a compression test- all 8 cylinders were strong, between 160 and 180 psi on 4 strokes. Oil pressure is good- 40 psi even at a low stumbling idle. The spark plug wires, distributor cap and rotor were all replaced last fall. I'm grasping for ideas. Anybody have any thoughts? I appreciate any insight any of you can offer.
