bassrascal02
- Jul 22, 2010
- 17
Rebuilt carbs, rebuilt fuel pump and changed out fuel filter. Took boat out set the idle screws as instructed by help from a previous thread I posted (thanks CharlieB). Got a great idle setting IN GEAR and IN the water. Had to run a few hole shots to get the overall idle setting right...but once set the boat jumped out of the hole and cruised faster than ever has before. Things were going so well I decided to do a little fishing.
Fired up the engine to make run back to ramp and this is when it went south. Engine bogged down and died for first hole shot...and when i got it to run there was no top end speed. Could only get 4k RPMs instead of just short of 6k RPMs that i normally get at full speed. Boat barely got up on plane....and as it was struggling to get full power the engine was surging and kind of jumping but never locked in on top end RPMs.
Only thing in the fuel system i have yet to change out is the accelerator pump for my 2 + 2 system....can those go bad or get clogged? Am I heading in the right direction or is there something else i didn't think of?
Thanks
Thanks
