Re: too much oil?
Faztbullet is spot on ..
i posted this to another thread
If you run a higher oil content you will be weakening the fuel/air ratio , this in turn will raise the cylinder temps as you will be
running a lean mixture.
Eventually if the mixture is too lean because the oil content is too high you will burn a hole in a piston or seize the engine as the cylinder temps get too hot.
It is a myth that putting more oil in a 2 stroke helps the engine through better lubrication.
Rich
