I have a pair of 115 EFI four strokes and one engine is giving me fits. It starts and idles fine. After between 15 and 30 minutes of cruising one engine looses power and starts to sputter. If I pull the throttle back to neutral it idles fine but will not throttle up. If I turn off the key and wait ten seconds the engine restarts and works fine for another 10 to 30 minutes or longer and then does it again. I have replaced all the fuel lines and bulbs and even swapped the lines from one engine to the other but the same engine has the problem. I have also swapped the low pressure fuel pump with the same results. The dealer has taken the fuel system apart, cleaned the injectors and all associated parts in the system with no success. He is stumped and so am I.
