rothfm
Ensign
- Sep 26, 2006
- 913
Hi All, Couple quests on my motors
1)Been working on a 1995 88Spl and a 1984 115. I have the Heads off, is it worth taking the head "covers" off for new gaskets. They look fine and still all painted over, the cooling holes look clear. Didnt want to seperate them if not really needed? Also what Head gasket compound is recommended to use?
2)Coil wires? The ends that go on the coils are corroded. They look hard-wired direct to the PowerPack. I suppose I cant just replace them without doing a Pack? I'd normally pull the boot back, but it doesnt slide up the cable at all. Do I have to replace the whole thing to get good Coil connectors?
3)Spark Plug wires...I see the fitted oem style ones, but is it doable to use short auto types or stick with the OEM type?
Getting most of my parts here on Iboats.
Thanks for any input.
