sutor623
- May 23, 2011
- 4,087
Just wondering if any of you have had any experience with the following issue on one of the 70's series Mercuries (or any motor for that matter). I have a '70's 45 (4.5hp) and just got the waterpump in yesterday. Went to start her up today, (first time since I've owned it) and she started right up. Idled pretty well, but had a bit of a misfire, nothing to write home about. Anyways, I warmed her up and had her running pretty well, put her in gear and did very well at open throttle. Had TONS of power for a motor this size, felt like it would BLOW my Evinrude 4hp away. Anyways I cut the motor off to go and get my video camera, because one of my buddies is interested in buying it, and came back outside.
Motor only wanted to start when I put the choke on. Ran with the choke on(choppy as you would expect) at idle speed, and up higher in the RPM band. The second I flip the choke off, the revs pick up, and slowly the engine dies out. Starts EVERY time with choke on, dies out EVERY time I take choke off. Won't idle or go high speed with choke off. The motor was JUST RUNNING FINE!!
So what are you guys thinking, ignition or fuel supply?
