Re: How to set the points gap on 1971 25R71 25 hp Johnson
Don't make it so complicated. As with ANY engine that uses points, merely turn the shaft till the points open at their maximum. Then adjust the gap to specs, in this case .020"
That will get it close enough. If you want to do it the "right" way, a special timing fixture is required. But it is not an absolute requirement to do it that way.
Well, when I turn the shaft using the flywheel nut and a wrench (clockwise), the point I'm working on appears to open up the widest when there is no apparent marking on the shaft that could be used as the guide instead of my own eyes. The area on the shaft is close to the key but not at the key, maybe 1/4" away or more. I'm aligning this imaginary area on the shaft with the rubbing portion of the point.
My guess was that I should be aligning the point rubbers with some marking on the shaft meant for that purpose. And what about top cylinder, bottom cylinder... as long as each point is 180 degrees apart in being opened/closed, cylinder order shouldn't matter?
Here's the results I have seen:
-without the points even being set correctly, the motor ran smooth, I had installed them and forgot to set gaps, pure luck?
-setting the points using the shaft key aligned with the point rubber, no crank
-setting the points using the raised thin "mark" next to the word "TOP" on the shaft, motor cranks but runs choppy
I'm turning the shaft clockwise using the flywheel nut slowly using a wrench and precisely stopping my mark point at the rubber portion of each point I'm setting.
All new points, coils, condensers.
