Hi all, my 9.9hp, Yamaha 4 stroke for a number of years would only go to 3500rpm then after say 5 minutes it would go to full revs, approx 4600-5000rpm and not miss a beat until cooled and started again.
Now the fault comes and goes regularly after it has warmed up.
I have tracked it down to the timing not advancing, or the low revs are there when it hasn?t advanced and full revs when it does.
Unsure how low oil pressure is supposed to limit revs to 2000 but the oil pressure switch is working and indicating pressure via the LED at the console. I have shorted the wire to earth which is supposed to limit revs to 2000 but this does not happen.
So far it looks like a fault CDI. I have disconnected the trigger coil and motor stops.
Does anyone have any thoughts on what may be the problem, a new CDI in Tasmania where l live is $500 Australian which is ok if l replaced unit and it ran correctly but not if it?s something else.
Have checked all connections including earth on unit and all seem ok.
Appreciate any thoughts on this problem.
Regards, Kevin
Regards, Kevin
