bassnbubba
- May 1, 2011
- 4
For reasons I can not explain I removed the vent screw from my lower unit for about 20 seconds. The next day there was a puddle of gear oil and the leak was coming from under the prop and under the metal ring behind the prop, I believe it is the bearing case. I then changed the lower end oil and now I can see a little oil under that metal ring behind the prop but no leak. Is it possible that when I removed the vent screw it forced the oil to go somewhere since the drain screw was still in? Or do I have to worry about a seal leak? The oil was changed three months before I removed vent screw that day and saw the puddle the next day. Should I worry or is there an easy fix. Im not mechanical enough to do a pressure test.
